- 24 Mar 2013
- C-137
Hi all,
So I have just installed a h100 and two msi gtx 670 power editions into my Define r4. Iv'e not had the define r4 long, and I must say I love the thing!
Problem is, I'm having some airflow issues, as the twin frozr IV coolers on the GPUs exhaust most of their hot air into the case, and I'm getting a crazy hotspot right where the h100 rad is. It only happens during gaming really, where the cpu and gpus are going full whack. you can really feel the heat once you open the front panel door and put your hand in front of the intakes, it is crazy hot. The top exhausts are blowing warm air out, but the air near rads is hot. I shouldn't even be able to feel that much heat since it's pulling cool air in at this point!
I have tried running prime95 on its own (so no gpu heat up,) small ffts, and the hottest any core went to was 80, rad fans (2x noctua nf-f12) were at about 50-60%, case fans at 5v using built in fan controller. As far as I can tell, the h100 is working fine, does 80 deg seem a little hot for a 4.5ghz 3770k @ 1.214v? I got the h100 from the ocuk refurb deal, I was expecting some better temps than my h80, but they are around the same, somewhat disappointingly
So I'm looking for some advice as to re-arranging my airflow, or if I should just go for a different case, which I really don't want to do tbh.
Here's how my airflow is currently set up:
https://www.dropbox.com/s/vlw6zf3jubmz2i0/define blank.jpg
Thanks for taking the time to have a looksie guys and dolls
