Airflow in a...cube
11 Jun 2003
Sheffield, UK
I'll shortly be building a setup that will see my PC buried in the desk.
It will be sat in a box about 30cm wide, 25cm high and lets say around 45cm front to back.
The current plan is a 200mm fan on the rear doing exhaust duties for everything (PSU, GPU, CPU) with 2x 240mm AIO radiators suspended near the top of this box at the front, both fitted with 2x140mm fans (so it will go 140mmx280mm hole in front of case with some basic dust filtering, through the first set of fans, through the first radiator, second set of fans, radiator, blow over the rest of the components and get sucked out the 200mm at the back).
Does this sound like enough airflow (lets say for single high end GPU and single high end CPU)? If not, any suggestions?
words*1000=picture and all that (excuse the ballin' mspaint skillz):
PSU's and drives are being mounted underneath in their own (similar) space. There will be another PC "down below" but it's pulling uber light fileserver duties with a 200mm front+back so I'm not too worried.
