Airflow with CM 690 II advanced Nvidia edition Case
18 Aug 2012
All of my computer components just arrived at my door from OCUK. After putting everything together and assembling the machine, I was wondering on how I should manage the airflow on the case.
Here's my build:
Case: CM 690 II advanced Nvidia edition
MOBO: MSI Z77A-G45 Intel Z77
Processor: Intel Core i5-3570K 3.40GHz
CPU cooler: Noctua NH-D14 Dual Radiator CPU Cooler
8gb ram
GPU: Palit gtx 560 ti
1 TB harddrive
some optical drive that idk the name of lol.
Front Cooling: 140 x 25 mm Green LED fan x 1 / 1200 RPM / 19 dBA (Included with case)
Rear Cooling: 120 mm fan x 1 / 1200 RPM / 17 dBA (Included with case)
Top Cooling: 140 x 25 mm fan x 1 / 1200 RPM / 19 dBA (supports 120 / 140 mm fan x 2)
Bottom Cooling: 120 mm fan x 2 (optional)
HDD cage Cooling: 120 mm fan x 1 (optional)
VGA holder Cooling: 80 x 15 mm fan x 1 (optional)
I have like 8 spare 120mm fans. Any help will be appreciated, and will surely help me out :)
Fill it with as many fans as possible, avoiding more input than output. (Tip: The fans blow towards the frame part of the fan)
Looking at the specs I'd recommend the two at the bottom/front blowing in and the rear/top out (Heat rises)
This is my set my fan setup with your case. I think the 80 mm fan at the rear of the CPU can reduce temps significantly.
AsRock Z68 Ex4 G3, [email protected], Ballistic Tracers 16GB,
5850 1GB(CFX), CM90 II Advanced, Crucial M4 256GB, 4 HDDs,
NH-D14, XFX 850W BE, Xonar Essence STX, BlackGold HD DVB.
