I've got a case that i'm quite happy with, but I'm concerned that I don't have enugh air flow? I have a side pannel intake fan which is 120 mm and a PSU fane the same and a 80mm extractor fan. I'm bothered that the temperature will build up inside, should I create air holes in the front of the case and add additional fans to enable more air in? Can the heat inside build up to the extent that it will be obstructive to the overall ai flow? Cou;d a case be too small to allow too little air to circulate? Some many questions and so litle time!
