Airflow
Zen
Zen
20 Nov 2006
Nottingham
Ok. I am having trouble understanding which way round does the case fan works.
How can I tell which way is the airflow, ie, blowing out and blowing in?
On the fan itself doesnt says it, but how could I tell? I know, plug it in and feel it, but I did, and both way round feels the same.
Look harder as there is usually an arrow indicating direction of air flow.
If not fire it up and hold a loose piece of paper near it or if a smoker let a small amount of smoke drift that way.
For air flow once sorted make sure you Suck in through the front and exhaust it out the back.
awesome!
I will have a look at it once I have decided which case I am getting this week :p
Thx.
You can also usually tell by the positioning of the 4 brackets holding the fan. The side with the brackets on is the exhaust.
