Airflow
6 Sep 2006
London
I've been thinking about several case designs for a while. The one that I would most like to create would literally be a hollow cylinder lying on its side with a box on top of it for Harddrives, PSU and DVD drives. These would be connected by long cables through a small hole to the motherboard which is enclosed within the tunnel. It would be lying down horizontal to the ground with the CPU HSF standing vertical along with the graphics card. The outputs from the motherboard and PCI slot cards would go out the side of the cylinder.
At each end would be roughly a 300mm fan. One input and one output. Both running at around 800-1000RPM which should be enough to get quite a large airflow through the cylinder. The DVD drives and harddrives would rely on the PSU fan to cool them.
I'd love to create a case like this even if just to see if it could actually work. Unfortunately I doubt I'll ever have the tools to do this. Maybe I'll juryrig up some sort of cardboard design for it just to test the cooling of the two large fans.
The other idea I've had most recently is more of a conventional design that might already be done. Basically I'm going with the idea of heat rising and using that to our advantage in case design.
I did up a quick diagram which can probably explain it better then I could here:
Basically you'd have 3x120mm fans at the bottom of the side panel tilted at about a 30deg angle upward. You'd have another 3x120mm fans at the top of the case pulling air out, maybe just 2x120mm and the PSU fan acting as the third.
For this I'm thinking it would probably be best to change the cpu tower to blow air upwards instead of the traditional out the back approach.
The problem facing both these designs is the graphics card. It present quite a large blockage to the air, especially if you have a 2900XT or a GTX. While this is good for the graphics card it potentially shadows the CPU cooler behind it from the air.
What do you guys think anyway? I'd be more likely to attempt the second idea of mine at some point. Probably when i'm sick of my current Antec Titan case and want to replace it. I'd just hack away at it and see how far I got. It could potentially be done with just some judicious hacksaw usage and some nuts and bolts afterwards. Obviously welding would be great but I don't have the kit or expertise to do that ;)
I've been thinking about something similar to your second idea, but with moving house and various other issues I just havent had the time or money to actually do it.
My idea was to mount the motherboard so the back panel faces upwards, and like you have the vertical airflow, but this way you dont have the graphics card blocking things. The only problem is you then have cables sticking up in the air, but is that such a bad thing?
The only other difference in my plan was to have the intake fans mounted vertically at the bottom on what would be the front side, then maybe have curved scoops behind them. The exhasts would be all along the top, with maybe an extra fan in the space left by any unused PCI slots.
Its a bit weird with someone coming up with such a similar idea, have you been stealing my thoughts?? :p
PK!
Great minds eh?
I was thinking of having the motherboard rotated like you said but that would end up with the outputs where the top fans should be.
For your idea the case would have to be lifted off the ground somehow so that air could get to the bottom fans. It could be good though.
Surely there'd be room for atleast one fan on the top aswell? most cases these days have a fan above the i/o panel.
PK!
that's 3 of us then!
I was going to have 3 fans at the bottom and 3 at the top, would have needed some good risers/wheels though.
get cracking then!!
get cracking then!!
Give me the cash for a new case I can mod the ass off(edit: literally) and I would =)
While I can't help with the OP's design, I was recently faced with a similar task... high airflow with low noise levels.
Here's what I came up with...
Of course, with the front bezel and side panels fitted, you can't see the uglyness that lies beneath. Works very well though. I'm basically forcing the fan in the PSU to draw the air into the case over the hard disk, cooling that at the same time.
It's only a P3 1GHz CPU and a 40gb hard disk but it's quiet, stays cool and does the job :)
