Hi guys,
I'm looking for a bit of advice on my loop setup, more the fill port. When i try to fill the machine with it on, the coolent doesn't travel into the system. Only when i power cycle the machine, the pump stops and the water than goes into the res. Do i need to move the fill feed? Just incase there is too much flow traveling through the fitting?
I've taken a photo for you. So when its on, the coolent just hangs in the feed. Turn the PC off and the water will be sucked down. You would think this is because there is too much coolent in the system, although it does this even empty.
Any pointers would be great.
Thanks.
Thanks.
