Airplay questions!
24 Feb 2008
Norway
I'm thinking of getting one of the B&W Airplay speakers, but I'm just wondering if it's possible to stream music from sources that aren't iTunes?
Reason I ask, is because i'd like to be able to stream various music & movie audio (from an iPhone and my PC), without putting it into iTunes!
Thanks!
It depends whether said application supports the airplay protocol or not. Surely the easiest option is to just use iTunes? The only reason you would buy an airplay compatible device e.g. speakers is if you intend to stream your media from something which supports airplay!
