Anyone using their AirPods Max connected to the output of a headphone amp?
Are these what I need (it's got a 3.5mm socket)?
Ta.
Ta.
Wired mode only work on the USB-C AirPod Max not the lightning ones.The adapter does claim to be Apple MFi certified which I thought meant it would work.
Now you’ve got me doubting it!
Oh you are right. I was thinking of lossless audio. Sorry about that.Sure? This suggests it should work.
Set up AirPods Max with your Mac and other Bluetooth devices – Apple Support (UK)
Find out how to set up your AirPods Max with your Mac, Android device or another Bluetooth device.support.apple.com
