Airport Express Setup Issues
20 Feb 2004
Hondon de las Nieves, Spain
I've just bought an Airport Express. I've plugged it into the wall socket and downloaded the latest version of Airport Utility
However when i open it and click Rescan it doesnt find anything. The light on the AE flashes a Yellow/Orange colour quite slowly.
What am i missing? I'm using Windows 7 on the laptop and want to try and connect the AE to my existing wireless network through a SKY router.
I take it you're trying to extend the network using the AE?
Without stating the obvious have a thorough read through the manual, I've recently purchased one myself and found it very straight forward with the setup procedure, although I found it very different to a standard router configuration of old.
Yes, that sounds about right. My plan is to have the AE plugged into my hifi so i can use Airplay to play music without the need for an ipod dock.
I bought the AE used and as bizarre as it sounds it looks like i have 3 manuals and none of them English, looks like they're German, French and Italian.
I've followed the online set up walkthrough but i expected the opening screen in the Airport Utility to detect the AE, do i need to use it connected with an ethernet cable for the initial set up?
I'm a moron
Logic made me realise that buying anything which is wireless second hand means the item is likely to be searching for the previous network.
A quick reset and i seem to be sorted
