- 14 Dec 2005
- Bath
Firstly, the below questions are based on my assumption that the Time Capsule's firmware & hardware is similar to the Airport Extreme (but with the addition of the HDD!)
The router my network's running off is a Linksys WRT600N (has both 2.4Ghz & 5Ghz and 802.11b/g/n).
I'm interested in adding a Networked hard disk to the network (not through using the router's USB port) for the sole purpose of Time Machine backups.
From what I know, Time Machine doesn't work with NAS's apart from the Time Capsule (which from looking at it, would be a waste of money as I don't want to use it as a router.)
From what I've read, the Time Capsule can be connected by ethernet to the existing router (or switch), and have all it's Wi-Fi & routing functions turned off - making it only work for it's NAS HDD (that'll work with Time Machine.)
Now that seems like quite a waste of money on a £200 device that has WiFi etc built in.
Now, thinking about it, one of the locations I'd put the Time Capsule when connect as above, has bad wireless reception......
From what I've read (especially this thread), when the Time Machine is connected as above, and I disable the Time Capsule's built in router and DHCP server, it can be assigned a different SSID (my network already has 2 (one for 2.4ghz & one for 5ghz)) and it'll be broadcasting without interfering my existing network.
My wireless devices could be given the Time Capsule's SSID & encryption details, and would be able to connect to that or the Linksys (depending on where abouts in the house they were) - and as both networks are connected together, all shared HDD's and internet would work fine joining together over the three SSID's from the Linksys & Time Capsule.
The tricky bit, is there a way of having the Time Capsule repeat/boost the signal coming from the Linksys? (instead of broadcasting on a different SSID, it'd be acting as a Wireless Access Point).
From my research about repeating, I know that WDS is needed, and accoring to here the Linksys WRT600N supports it. (whatever it actually is!)
So, would the Time Capsule be able to repeat/boost the Linksys's signal? If so, how? (I'd keep the two router's connected together by gigabit as obviously the location of the Time Capsule would be one where the Linksys's signal struggles to reach.)
Anything wrong with the idea of broadcasting on a different SSID? And any ideas about broadcasting on the same SSID?
Blimey that's a long post! If your still reading this far and understand what I'm on about you can have a cookie
Thanks
Ed.
EDIT: Realized title error, should be "Extreme" not "Express" (as thats what the Time Capsule's based on).
Thanks
Ed.
