- 13 Feb 2004
- South Shields
I decided to make life simple the other day and buy a mac!
First stage of this plan was to get an Airport Extreme and get it setup at home to beam out my 50MB VM connection.
I had read that the R30 firmware update for the superhub allowed access to a "Modem" mode on the Superhub.. so rushed out to get a gigabit switch and some cat 6 cabling!
The way my network was to be setup is as follows -
Superhub in Modem mode for the main Internet connection in.
Connect the Superhub to a gigabit switch..
Run one cat 6 cable from the switch to my PC for wired Internet access and one cat 6 to the WAN port on the Airport Extreme..
And then I expected it all to work in unison.
It didn't.
Right now I have tried every single combination of the hardware I have and have had no luck at all in getting the AE to actually allow internet access.
The last attempt was a follows:
One cat 6 from the Superhub to the AE WAN port
One cat 6 from a hub port on the AE to my PC for network access.
And still no Internet connection.
I even tried cat 5e cables just incase the cables were above standard (which I knew they were not but tried out of sheer desperation.)
My AE has the following settings applied, from memory:
DHCP is set to auto (But reverts to manual all the time???)
I have tried setting the AE to both supplying IP addresses for attached hardware (Which I believe is the correct setting) and have tried it using a singular IP..
I do not have a guest network available.
I have tried all three network ranges of 10.0, 172.16 and 192.168 without any luck.
I am also consistently getting a Beginning DHCP error and an Edning DHCP error on ranges..
I am lost.
I though apple hardware was supposed to be simpler.
I'm tired atm so may have left something out.. but I hope someone understands what I am saying here.
The really annoying thing is I can't get my settings without disconnecting the internet.. which means I can't post this!
Sick isn't the word.. please help lol
It didn't.
I am lost.
