Hi,
Have there been any minor/major OSX updates in the past week that may affect Airport, or its ability to connect to a wireless network?
For the past 2 days our 2010 iMac is unable connect to my wireless network. It can see the network, but times out when it tries to connect. Router configuration and Airport settings have not been changed. We've had no problems in the past 5 months either which is odd.
FYI our old laptops can connect no problems (posting from work laptop) from the same location within the house.
I'm going to log onto the router in a bit and check the config, maybe change the channel as there are an awful lot of Sky networks in the area - prob won't make much difference though.
Any suggestions/advice?
Cheers,
Grant
Cheers,
Grant
