Hey all
I am making a self validating AJAX form, which was working fine until I tried to get clever and make it handle multiple fields. It was working fine when it only validated the 'username' field, but when I tried adding support for extra fields, passing variables via a function it ceases to work and gets stuck at readystate == 1, and thats still on the username field without even trying a second
In the individual fields function, if I change
to
and declare the "whichField" variable so its static, then it works, otherwise it gets stuck
obviously I need some way to use the handleHttpResponse function to be able to update different fields
Code:
var url = "reg_val.php?username="; // The server-side script
function handleHttpResponse(whichField) {
//alert(http.readyState);
//var whichField = "username";
if (http.readyState == 4) {
if(http.status==200) {
var results=http.responseText;
var results_array = results.split("|");
if (whichField == "username") {
document.getElementById('res_user').innerHTML = results_array[0];
document.getElementById('username').className = results_array[1];
else if (whichField == "email") {
document.getElementById('res_email').innerHTML = results_array[0];
document.getElementById('email').className = results_array[1];
function getHTTPObject() {
var xmlhttp;
if(window.XMLHttpRequest){
xmlhttp = new XMLHttpRequest();
else if (window.ActiveXObject){
xmlhttp=new ActiveXObject("Microsoft.XMLHTTP");
if (!xmlhttp){
xmlhttp=new ActiveXObject("Msxml2.XMLHTTP");
return xmlhttp;
function requestUsername(field) {
document.getElementById('res_user').innerHTML = "<img src=\"images/icons/indicator.gif\">";
var sId = document.getElementById("username").value;
http.open("GET", url + escape(sId), true);
http.onreadystatechange = handleHttpResponse(field);
http.send(null);
function requestEmail(field) {
document.getElementById('res_email').innerHTML = "<img src=\"images/icons/indicator.gif\">";
var sId = document.getElementById("email").value;
http.send(null);
var http = getHTTPObject(); // We create the HTTP Object
Code:
Code:
handleHttpResponse
