Akasa 62 Case Fans
26 Mar 2005
I've been told that the Akasa 62 Case now comes with 2 120mm case fans.
I was wondering if anyone who had this version of the case can comment on their thermal and noise performance or would I be better off getting a couple of Noctua 120mm fans instead?
Thanks!
Not again :confused: "Yes the case comes pre-installed with two Akasa clear fans" this question has been asked 1 zillion times, look at the Akasa Eclipse 62 Threads for all your answers. Unless you have the hearing ability of a Bat, I am sure any 120mm fan won't make you deaf if you are too close.. :D
