Just orderd my fans and UV lights to go with my OCZ modstream UV cable psu thing, orderd the fan with out seeing any details about it, looked on the akasa website and its 28db??? is this loud??? btw put in some details
Application PC Case fan
Fan dimension 80 x 80 x 25mm
Fan speed 2500 R.P.M.
Fan airflow 28.76 CFM
Fan air pressure 2.43mm H20
Fan life expectancy 30000/hrs
Bearing type Sleeve Bearing
Connector 3-pin with RPM sensor wire
Voltage rating 12V
Noise level 27.45 dB(A)
Voltage rating 12V
