How many thermal probe leads are supplied with the FC-03?
Does the controller read CPU & motherboard temp from computer BIOS? Or only measured through the probes ? Ideally I would through the Bios (like the Asus Ipanel) plus through videocard drivers. That way can connect up CPU, videocard and my powerful exhaust fan to the FC-03.
Does the controller slow down and speed up the fans to your pre-determined level? Ie if CPU and mobo are under 30 degrees C in quiet mode, when it detects 35> for CPU, 45> for GFX spins the fans up.
I have the Asus ipanel from my old motherboard, will it fit into my new board?
