**AKASA Akasa Venom A20 AIO Cooler Reviewer Needed**
Status
Not open for further replies.
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
We are looking for someone to do us a review of the Akasa Venom A20 Dual Radiator Liquid CPU Cooler. We need you to be able to show your findings with everyday use and with some extreme use to be able to find out how this cooler can perform. If you have done any sort of review before please send your work to [email protected].
1. We would need tests from Idle, Gaming and CPU overclocking.
2. We would also need it to be a system and not on a bench to show the normal use of the cooler.
2. We would really need this properly documented with a good write up of the testing procedure and show your findings. A conclusion would be ideal at the end of the write to show how you think the cooler has performed.
3. As you can imagine we would like the system to be of a fairly high end CPU due to the overclock tests. So please posts your specification in this thread so we can ensure the cooler is put to the test properly.
You get to keep the cooler for doing the review. Your review will also be used on the forum to go with the product announcement.
Any questions let me know. We will hopefully be sending the cooler to someone next Tuesday.
https://www.overclockers.co.uk/akasa-venom-a20-dual-radiator-liquid-cpu-cooler-hs-104-ak.html
Nice :) I'm not experienced enough in watercooling, but sweet deal for someone with a little time and experience :)
Last link is invalid by the way
Thank you for the interest guys. The people that applied where very close in regards to write ups and specifications. Everyone has been emailed back and we will now close the thread.
Thanks again.
Status
