Which case would be better for cooling?
I'm going to have a Q6600 OC'd @ 3.6Ghz with a Tuniq Tower, and 2 x HD 4870's in Crossfire unless someone convinces me to get some other graphic card.
Basically as you can imagine the Case will get mightly hot and was wondering if the Akasa Eclipse 62 will be able to sufficiently cool it with only 1 front 120mm fan and one 120 exhaust, as I want to get that case becasue it's gorgeous with the side window and some lights inside.
Thanks for the help!
Although, if the other Akasa Cases have better cooling than the 62 then please advise me.
7 fans: 6x 120mm + 1x 200mm....
More than the Tempest...
