Hello all,
I have an Akasa Eclipse 62. Up until last few months its been fantastic. I like the look, space, design everything about it. Last few months the rear fan started to vibrate, i put up with it putting books ontop of the case or tapping the back plate where the fan is located usually stopped it.
Recently i decided to get some uber fans to quieten my PC and also get rid of the vibrating noise once and for all. I bought 3x Noctua P-12 and a fan control unit.
These fans are whisper quiet!!! but i STILL have the vibrating rear fan. Its something to do with the actually build of the case. When the side panel is off it doesn't vibrate, when i put it on and lock it in it twists the case or something and it starts to vibrate again. Pushing the rear silver panel with my finger also stops the vibrations...
Has anyone else noticed this? and is there a solution?
Cheers
Cheers
