kkthxbye said:lol why would a review say it was plastic if it wasnt, load of pics here
http://forums.overclockers.co.uk/showthread.php?t=17671494
PinkFloyd said:If your buying a case for its aesthetic looks on the exterior your looking at the wrong case.
Craig321 said:I just read a review on this case, it says it has a plastic front?![]()
Is that true?
Thanks,
Craig.
so nothing with a window in it....WJA96 said:I don't know of any cases at all that are 100% aluminium alloy in every aspect of their construction, so to start knocking lumps off the Eclipse because it has a plastic front is basically lay youself open to ridicule.
Craig321 said:Coolermaster Wavemaster. I haven't found any plastic in it![]()
Amidar said:But who the hell would want a Wavemaster![]()
Craig321 said:What's wrong with them? Apart from the 80mm fans?
WJA96 said:What are they made of?
PinkFloyd said:Yes it has, but its a fairly decent quality plastic that can take quite a bit of abuse.
Craig321 said:I'm not talking about the fans being plastic, I'm talking about the case.
WJA96 said:Yes, but you accept one, why not the other? The fact is - plastic isn't carp, it's just different.
WJA96 said:It's extremely nice plastic. The two HDD lights only work if you have a secondary header eg. on a SATA or PATA add-in PCI card.
Craig321 said:Ah right. I think if I got this case i'd just have to get a add-in PCI card just so I can make the other HDD light work![]()
PinkFloyd said:![]()
ok.... lol
I haven't got any of the lights on the front connected up![]()
Craig321 said:I look at my HDD light all the time anyway![]()
