Akasa Eclipse Side panel
7 Jul 2004
Gloucester
Is the side panel with the 120mm fan on it worth the extra £20? Has anyone got one & noticed any temp difference?
Just wondering cos I'm going to be ordering the eclipse & wondering if I should get that side panel or the windowed one...
Ive read on here a few times now that it makes a difference to temps, especially gfx card. I think its an akasa amber fan you get with it so itll be nice and quiet to. If your also thinking of the window panel then you must want to see inside your case so your better off with that. If your gfx cards are running hot or you have an SLI setup then id imagine the 120mm fan would be a good edition.
Mark
The original ones were fitted with Ambers, the new ones have a high airflow black fan, but it is still very quiet.
If you are running a high performance graphics setup then this is highly recommended by both myself and several others.
