Hi All, ive finished building my computer a couple of days ago and i am having a bit of a problem with either my fan controllers or my fans.
I have a 360 rad which uses 6 sickle flow fans in push pull.
i also have 4 case fans (xigmatec fans)
I use an akasa fc six fan controller and an fc trio fan controller.
I am finding when the sickle flow fans are connected to either fan controller they make a buzzing sound which is quite annoying. the noise occurs at all fan speeds. When i power the fans direct from the psu the noise isnt there. The xigmatec fans work fine on the controller and dont make any buzzing noise at all.
The sickle flows are fairly noisy when on max speed (powered direct) and i dont need them on max for cooling my cpu loop.
any body else had this problem? any solutions?
im guessing its a case of the fans being kind of incompatible with the akasa fan controllers as the xigmatec fans seem to be ok. anybody know of which fans work fine with the akasa fan controller range?
ta
Minty
ta
Minty
