I'm about to install 4 new fan's into my computer, they are 2 Scythe Kaze for front ventilation, A Noctua NH-U12F CPU Cooler and A Delta 120mm EHE for the rear of the case.
I also got the Akasa Fan Controller Pro I know that it will be able to control 3 of the fans but I'm not sure on it being able to control the delta, Is it likely to blow A fuse or do you think It will be fine?
Quick response needed, starting soon
Ash
Ash
had to remove the delta as It wouldn't boot, only when all fans where on low.
