Akasa Mirage cooling - is this overkill
18 Jun 2005
Background
Am running my Mirage with 3 case fans....1200rpm scythe fans - front intake to cool both hard drives, rear out take for cpu, side intake to cool gpu. The 2 intake fans make the most noise as nearest to me (especially on the sidepanel over turbulence caused by proximity to grille on panel), so both of these are controlled by the motherboard and run most the time around 900rpm. The rear fan runs on full speed (1200rpm), as does the cpu fan (1200rpm also) which is also a Scythe fan which came with my Ninja Rev B heatsink. All very quiet and quiet happy but think I could do better with cooling.
Question
I am thinking of adding a Scythe Kama bay cooler (like a CM 4in3 module) to the front of my Mirage so it will pull in cold air, aim directly at the fan on my scythe ninja, and then exhaust out the back by another 120mm fan. Sort of an air tunnel effect.
http://www.modthebox.com/review458_1.shtml
The fan which comes with the Kama is an 800rpm job and is dead quiet and pushes a reasonable amount of air. The front panel on the Mirage is a small bit restrictive (even though it is vented). Not a problem for the intake for the hard drives as it can also pull the air from a hole at the bottom of the front bezel. May be a problem further up but I am thinking it will still improve matters as the cold air which gets to the cpu now has already passed over 2 hard drives.
I can't believe you would need so much cooling.
I'm running 2 ambers at 5v in my eclipse, and everything is ice cool even under load.
So, overkill imo
So, overkill imo
I am running 3xScythe fans at up to 1200rpm, plus a Scythe Ninja cooler.
My cpu idles around 39/40. Same for motherboard. (According to Intel Desktop Utilities). My gpu idles in high 50's.
What components are you using that they run "icel cool" at 5v ? Can't see how that is possible at 5v.
colder room probably, everyones temps are relative to themselves only.
you cant compare temps between two totally different places and systems.
If you need more fans, you need more fans.
IMO, he doesn't need more fans. Temps look fine to me. If he was having major instability then more/faster fans might be required.
I'd rather lap the heatsink, tidy cables, even make my own duct out of paper before I put in any more fans. They're always a last resort as they tend to add more noise.
I've a friend (sagaboy2) with the eclipse, and he has Ambers at 5V and a heavily overclocked X2 with load of hard drives and he has no instability or noise issues at all.
See my sig.
My room is usually fairly warm too.
The temps you are getting there fine
P4radox, sound like I'm in the same situation as him :)
No issues at all.
I have no issues either with stability or heat. Just thought my temps a bit high compared to what other people with Eclipses were reporting. Then again, I have seen Asus boards that read 10 degrees lower then the Intel board so it is down to the bios I guess and how it reads core temps. Probably a waste getting that Kama Bay cooler, especially as I would have to sacrifice one of my opticals.
