ted34 said:Its on special with ocuk. Most people seem to prefer the mirage but i already like the eclipse front. Have heard of a few fronts been modified and just wanted to see what they looked like - tried google and couldnt find anything but if anyone here has any links
Yewen said:Check the cases gallery, the front is nicer than the Mirage in my opinion, looks a lot better.
Eclipse is the better buy, and actually is easier to silence than a Mirage is.![]()
Less ventilation / Air turbulence I would guess....ted34 said:Hows the eclipse 62 easier to quieten when its the same case except for front panel?
Mark A said:Im going to be modding my eclipse front panel soon. Well i say modding more making a whole new one out of wood, modders mesh, black stain, blue leds
Mark
Its still customNeon said:wood ?![]()
PinkFloyd said:Its still custom
I would presume he is keeping it in theme with the rest of the case
Yep Ash to be precise, it'll look modern and fit in with the sleek look of the case, hopefully. I'm going to chamfer the edges to match my speakers that are suspended above my setup. The Ash is going to be stained black and will have a satin finish applied. If you have ever seen furniture made of black Ash then that is the effect I'm after. Then I'm going to use black modders mesh for the front fan intake. I'll keep the layout as it is and try and include the front pci in there some how as i think it's useful. I'll make a thread when i get the timber, it'll cost £33.52 inc vat and del so not too expensive should it go **** up. I'm not 100% sure if I'm going to use blue or red LED's for this one, id have to change the LEDs in my fan controller if i go for red.Neon said:wood ?![]()
Yellow?, mine are green. i never even notice them tbh. But i can see what you mean it is a tad bright. I think when i do this mod i'll swap it out for a less bright led or even a red led but im undecided yet.ted34 said:Any news on the mods yet guys - Also does anyone find the blue on led really bright and makes it hard to see the yellow leds below it - ive had to put 2 lines of duck tape between the 2 leds
