Cables are braided
If memory serves - you need to connect for power (molex or sata - dependent upon which Akasa splitter we are talking ) then you need to connect the connector marked as cpu header (or something like that) to the motherboard cpu fan connector and lastly you connect whichever fans you want to run at the same speed to the other connectors..
Am running 4 x 120 fans with mine without any probs ( so far anyway!) .
Check board that it is playing PWM?
Hope the above helps![]()
