Akasa Venom mounting
21 Sep 2010
Hi all, can anyone tell me if it is OK to mount a Venom cooler either way round. In most of the illustrations I have seen the fan is on the side exhausting through the rear of the case. If possible I would like to mount the cooler with the fan at the bottom exhausting through the top of the case, as it would suit me better. The cooler will be fitted on an i3 530, the motherboard is an Asus P7H55-M-USB3 and the case is an Antec 300. Is it critacle which way it is mounted on the CPU?
Thanks
46fan.
