Akasa viper 3pin
2 Aug 2010
Sussex
So I just got some Akasa Viper fans to replace my stock corsair h70 fans and basically I have all my cables set up in a way that I only have 3 pin connectors handy to connect to and as far as I am aware they can just plug straight in but basically I don't want to mess it up so thought I would quickly check on here - Is it OK to literally just plug them into a 3pin connector to get them going full speed?
Yes it's fine. You can also slow the fan using a fan controller.
You can also use this to split the motherboard PWM output to control more than one fan and they can be daisy chained if desired.
Theyre not quiet by any means, when running full pelt. You'll want to pick up one of the above, I've got it attached to 3 vipers and they cool the radiator perfectly at half the speed :)
