Well its about 30 degrees outside, my 8800gt is idling at 60 degrees, going up to 70 ingame, and it gets waaaaaay too loud for my liking.
I want a cheap and efficient cooler, and this one looks great
http://www.overclockers.co.uk/showproduct.php?prodid=HS-047-AK
its cheap, looks easy to do, and reviews are positive.
One thing I couldnt find, is whether you could change the Fan speeds? because the power cable doesn't go into the GPU, maybe you cannot do this?
If anyone could clarify that, thanks a lot.
also, anyone know what the best shipping method is to abroad? I don't mind waiting a few days, as long as it arrives.
