Akasa Vortexx
26 Jun 2008
Bristol
If you attach one to a 4850 do you need the ram sink things as well or just slap it on and slap it in?
Cheers :cool:
All the stuff i've read say that vram (sp?) needs heat sinks. oh well i'll go with Azza on this one.
Great review btw m8.
Is the Akasa Vortexx supposed to be best for the 4850, because i thought s1 was best for the price but due to the size it doesnt allow the cards to be crossfired but i saw a picture on these forums with the s1 and was crossfired. So i dont know.
What is best and what should i get for it s1 or the vortexx and plan to crossfire?
~Slash
you can do S1 in crossfire and you can even use 120mm fan on both.
providing you lose the casing on the top fan, it fits on my rig in the sig below by a couple of mm's.
i think the S1 has better performance but it doesn't exhaust the air like the Neo so you have to factor that in with your case airflow etc and work out which one is best for you.
