Anyone using an Akasa ZEN...what fits in it. I was lookking at this case to build a small C2D system...with possibly an 8800GTS and a Tuniq Tower or similar. Is there enough room...also how is the cooling...good enough for a decent overclock?
Had just enough room to fit in a TR 120 Ultra Extreme with an IP35-Pro, if that helps. GTS should fit (had a 2900XT in mine. Didn't start overclocking while it was in there (got a Lian Li A10 now), but cooling seemed decent enough if you have a good H/S like the Tuniq.
Very good case for the price and the fans are pretty quiet too.
It has a wierd little tunnel thing coming off the side vent you'll need to remove if you put a HSF of any size in, but it's easy enough to take off. I think it's a cracking little case, especially for the price.
