- 4 May 2004
My black Zen case arrived this morning. The case is quite light and looks great. The optical drive mountings are a cool feature and having 2 120mm fans included nice. I haven't yet built the PC but I can already see some issues:
1. The thumb screws are normal screws mounted in a plastic casing, they feel very cheap.
2. The side panels are awkward to fit.
3. I cannot find a vent at the front of the case. I put a torch behind the front fan and saw very little light coming through.
4. The automatic sprung cover for optical drive blocks the eject button when the cd tray is out.
5. The cover at the bottom of the case for usb/audio could block your usb stick if it is large enough.
6. The usb ports are upside-down so and activity light on a usb stick will face the floor.
7. The power button is also a bit wobbly!
I appreciate it is a budget case but my old superflower case that cost me £25 has much better build quality.
What's the opinion of other owners? Is the air-flow good? I see there are plenty of vents along the side of the case but I cant find one at the front!
Thanks.
Thanks.
Does it really matter?
