Akasa's latest products - IN STOCK NOW!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
We have some new toys in stock. All pre-orders will ship today with more stock available to purchase.
Akasa AK-CC4008HP01 Venom Voodoo CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3 @ £44.99 inc VAT
Venom Voodoo, this cooler is definitely rock and roll. Venom Voodoo delivers ultra high performance enabling serious system overclocking. The 12cm killer Viper yellow fan uses S-Flow blades providing 30% more airflow than a standard fan at the same speed. PWM function ensures quiet operation during normal system use and performance cooling under load.
The Black cover and copper heatpipes combined with the Viper yellow elements creates a striking combination which adds pazazz to any system. Six high capacity heatpipes with direct CPU contact provide rapid heat transfer from CPU to high grade aluminium profiled fins. Anti-vibration rubber fan mounting pins provide easy installation and help to eliminate a lot of fan noise. Adjustable mountings ensure full compatibility with all current AMD and Intel CPU’s.
Dual 12cm viper fans giving extreme performance in a push-pull setup where the first fan “pushes” air through the heatsink’s cooling fins, at the same time the second one “pulls” air through from the other side. The combined airflow of two 12cm fans results in more efficient heat dissipation and consequently lower CPU temperatures.
- Dual 120mm PWM fans in killer viper yellow
- Six high capacity 6mm heatpipes with direct CPU contact
- Award winning S-FLOW fan blades provide 30% more airflow
- Rubber fan mounts for easy install and quiet performance
- Fan Dimensions: 120 x 120 x 25mm
- Fan Speed: 600 - 1200 RPM
- Max Airflow: 83.63 CFM
- Noise Level: 6.9 - 28.9dBA
- Cooler dimensions: 131 (W) x 129.5 (D) x 163.5 (H) mm
Only £44.99 inc VAT.
ORDER NOW
Akasa AK-FN062 Apache Black Super Silent 140mm Fan - 4 Pin PWM @ £14.99 inc VAT
Super silent 14cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction.It’s powerful and quiet!
- Super silent APACHE BLACK 14cm fan
- S-FLOW fan blade design delivers 30% higher airflow
- Super silent with PWM speed control
- Hydro Dynamic Bearing extends fan life
- Application: PC case or heatsink fan
- Dimension: 140 X 140 X 25mm
- Fan speed: 600 -1300 RPM
- Max airflow: 89.55 CFM
- Max static air pressure: 2.76 mm H2O
- Noise level: 12.5 -22.19 dB(A)
- Voltage rating: 12V DC
- Bearing: HDB (Hydro Dynamic Bearing)
- Fan life expectancy: 50,000 hours
- Connector: 4pin PWM
Only £14.99 inc VAT.
ORDER NOW
Akasa AK-FN063 140mm Ultra Quiet Viper Cool Fan - 3/4 Pin @ £14.99 inc VAT
High performance 14cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
The Viper fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. Killer Viper yellow colour makes this fan distinctive and unique.
- High performance 14cm fan in killer VIPER yellow colour
- Super silent with PWM auto speed control
- Hydro Dynamic Bearing extends fan life up to 50,000 hours
- Fan speed: 600 -1600 RPM
- Max airflow: 110.61 CFM
- Max static air pressure: 3.12 mm H2O
- Noise level: 12.5 - 26.01 dB(A)
ORDER NOW
Hi,
How would this compare to a Prolimatech Megahalems Rev B with the same fans?
Is the Venom ok with taller ram?
Would you know what kind of max temps on prime i'd get on a i7 920 @4.2
Cheers :)
the voodoo and the megahalem with the same fans would perform very similarly.
I guess it's no brainer to go with the voodoo then, as it comes with the fans :) i have tall ram, so there be enough room would u say ?
It was out of the
megahalem
voodoo
Or Corsair Hydro H80.
But was worried about a lot of heat coming out the back due to the radiator on load of heavy gaming, as it's under my desk. my legs roast enough as it is with the crossfire card :D
I do a lot of heavy gaming @ 1920x1200.
Cheers.
if you've got Gskill ripjaws or something of a similar height then i;d say go for it. i wouldnt be so sure if you had corsair vengance though. someone did a review of this recently so i'll see if i can dig it up
*edit*
here it is
http://forums.overclockers.co.uk/showthread.php?t=18315649
looks like you should be OK if you dont use the RAM slot closest to the cooler, but in every other slot you can have any height RAM you want
Yes i have some Corsair Vengeance 6g :D
There not installed in the first slot mind. so maybe just fit ?
neill, any chance you could find out for me please mate :)
We are going to stock the new cases, however there is no ETA from Akasa yet
EDIT:
Infact I just MSN'd my Akasa contact who advises it should be mid-October.
are you getting the new case by akasa ? , if so have you any idea when ?
also how does the Venom Voodoo compair to the venom ?
http://www.akasa.co.uk/update.php?tpl=product/product.detail.tpl&no=181&type=Chassis&type_sub=Full ATX&model=AK-TOX-01BK
I would imagine that the Voodoo would compare nearly the same as the Venom if the Venom had push/pull fans.
From my own experience with the Venom, there's only a small drop in temps using the push/pull setup, it's been a while since I checked but I think its about 2 - 4°C.
You say that but we are selling the Level 10 GT in white.
Better than I expected anyway.
its certainly the most vulgar case your selling (and if you guys dont sell it then i very rarely know about it). some people will appreciate it, but i much prefer the subtle cases like the raven 2
