I am in the process of designing a DIY home alarm system based upon an Arduino.
I have worked out how to process the information I need from PIRs, door sensors etc. and have started looking at an outside siren and wondered if anyone on here has any knowledge of the wiring.
This video shows a basic overview: LINK
Assuming most boxes work on the same principle as the one shown in that video, it appears that the siren is silenced as long as there is:
A) 12V DC power supplied
B) 12V- supplied to the siren terminal
Beyond that, the strobes will be switched off when 12V- is connected to the strobe terminal.
My local CEF sells a Challenger AU1000WBX box: LINK
The manual is here: LINK
The connections are as follows (admire my MS Paint skills):
Assuming the logic I've described above is correct, I can power the device with a 12V supply and use relays to trigger the siren and strobes.
RTN- is mentioned as being part of a tamper circuit. Does this normally tell the panel when the bell box has been tampered with or is it something I haven't understood?
Otherwise, does my understanding of the wiring look sound?
Thanks in advance.
PS - I'm not tied to this particular bell box, so any more suitable recommendations are welcome.
Thanks in advance.
