Alarm LED
Ish
Ish
11 Jan 2006
West Midlands
Hi
I noticed on my bike last night that the alarm led just stays on constantly when the alarm is armed but usually it flases once a second. When disarmed it turns off.
Everything seems to be working fine on the alarm and the manual doesn't mention anything about the led staying on all the time.
http://www.datatool.co.uk/consumer/support/index.php?product=veto_evo&action=search
It was fitted to my bike in 2002.
It is a loose connection somewhere as when I started the bike up the led would flicker sometimes even though it's supposed to be off when the bike is running. I took it for a ride and it seems to be ok for now but there is obviously a loose connection that needs investigation.
