alaska amber 120mm worth it?
5 Mar 2006
mansfield
Hey,
Getting a alaska amber l8er today wunderd if it is worth it as it has low'ish cfm but it will be where they wasn't a fan before so all helps right?
And also do you think it will cool my gfx card a little by more air being in the case fron the amber? as my x1800xt gets rather hot when i play games i.e 72C.
Cheers all :)
So if i add the 120mm in the front then add a 80mm in the side what temps u think i will get down 2 ? about 5C lower or even more?
Well atm my cpu gets to like 40'ish when i been gaimg for like 3 hours so anythign below that would be good and also cool my gfx a little would be good.
It should lower temps, that's the setup i had in my old case and it gave good results.
BTW, nice rig for a fourteen year old ;)
Ow and i just found a slot next to my gfx card which is honey comb and is 60mm down 125accross so does that mean i can fit to 60mm fans in there?
But has no screw holes so that means i crnt uuse it or can i jsut add soem holes?
young lad said:
Cheers :) daddy paid lmao
Cheers for that how lower did it go?
You had it the easy way then, i had to pay for my rig myself a few months ago, i was only fourteen then as well :(
As said above, the temps went down by about 5-6c on the gfx card and about 3c on the cpu. Mind you i did have two 80mm rear fans as a pose to only one.
Yeah but dad had won 2k in the bookmakers so he said merry late crimbo przzie lmao :) might get a few more fans then try soem overclocking tbh :)
Yep, both your CPU and GFX seem to be getting some good overclocking results atm.
