So I upgraded the Duron 1000 to an Athlon XP2400+ on the motherboard. I've also flashed the BIOS to the latest version (which should support the XP2400+).
On the frequency screen in the bios:-
CPU Speed: This seems to reflect the current setting (15xCPU Clock)
Spread Spectrum: Enabled - What on earth is this?
CPU Clock: 100 (100 - 132 range) - I cannot set this anywhere near 132, and why isn't 133 there?
DDR:CPU Ratio: 2.00x (2.00x or 2.66x) - I've left this as 2.00x to try and help.
At the moment, I'm runing the CPU at 100 (15*100) = 1500mhz to ensure no problems. In Windows XP it reports the processor as an Athlon XP2400+, but the running spead as 1500mhz (XP1800+).
If I try upping the CPU clock, eg: to 130 or above, either the BIOS doesn't even boot up, or you get into the Windows loading screen where it then just sits forever....
So I'm a little confused. My gut feel is the motherboard is at fault somehow? I've even tried taking each of the two memory sticks out to ensure they're not at fault.
EDIT: I'm surprised there isn't just a 'Default' option to just the processor at the correct/appropriate settings rather than manually having to set them. I also cannot find a manual anywhere online
