albums shrink
4 Nov 2010
i'm trying to put an album onto disc but it wont fit its 36 seconds to long nero says something about overburning... but how can i shrink it so it will fit and put tick in box where it says no pause between tracks with out that its nearly 1 mins 30 to big ...any help BIG THANKS
Not sure if there's much you can do other than reduce the number of tracks on your album. You could maybe use some audio editing software, like Audacity to remove any gaps at the end of your tracks, which might get you enough space, but that would be an awful lot of work.
Why not just actually use the overburn feature? 36 seconds should be fine so long as it's not terrible quality media.
