ALDP touchpad and Linux Mint 10
If you are going to be using linux the you are going to have to do things in a slightly different way. The link you showed seems to be pretty simple to follow and as long as you backup your xorg.conf its easy to sort out if anything goes wrong. Just get stuck in and I'm sure you'll sort it out.
to set mouse from command line used to use the xset command
xset --help
something like (IIRC)
xset -m 4 6
4 is threshold and 6 is accel rate. (or something) I always find mouse feel on linux to be a bit poor, the accel curve is different to windows .
many ways...
put it in a script:
#!/bin/bash
xset m 22
save that as mouse.sh , make executable and add it to your startup items in kde / gnome what ever
I followed this youtube video (
) and entered
#!bin/bash
xset m 5 2
as my script and added it to the startup applications list but it has no affect on reboot. What am I doing wrong? Please help this is really bugging me lol
I thought it may have been a permissions issue so I made myself Admin and gave all groups read/write permissions for the srartup-script.hl script I created. It still doeant run on startup :(
I can double click the script file and run it that way but I want it to autorun on startup. Please can anyone help, Id be eternaly greatfull
many ways...
put it in a script:
#!/bin/bash
xset m 22
I'll have to try it myself a bit later but I think the clue is "make it executable"
ie right click on the file > properties > permissions > tick the the box for execute?
may be wrong?
I noticed that straight after I sign in the mouse speed is as I want it, but then after about 3 seconds goes back to the default speed :(
I've tried copying the script to the init.d folder but still no luck
Here are all the input devices Mint sees:
xinput list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ ImPS/2 Generic Wheel Mouse id=12 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ Sleep Button id=9 [slave keyboard (3)]
↳ HP Webcam-50 id=10 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=11 [slave keyboard (3)]
↳ HP WMI hotkeys id=13 [slave keyboard (3)]
Does this look ok? I have to Mice apparently, could that be the problem?
something else will be 'readjusting' the mouse settings after you log in . You need to find out how your OS handles this and remove it or change it etc.
No use putting this script in init.d as that is for boot up / start up scripts, you want this to be ran A) after X has started, and B) after you have logged in.
Its a bit (or a lot) of a hack but you could work out exactly when X adjusts the speed itself and put in a "sleep 30" (or whatever time in seconds) to the script so that your command runs afterwards...
Either that or do as previously shown and edit xorg.conf
