- 14 Dec 2011
Whilst installing some new fans to my setup the weekend, I have noticed what appears to be algae starting to coat the pipes, most evident on the underside of the tubing, but the blocks look largely unaffected. Never had algae before in my loop, but since I replaced it and put battery water (it was new) and EK blue UV additive that comes with the EK HF kit, I'm somewhat surprised to be facing the issue tbh.
I'm a little bit lost as to course of action, I have thought about trying to introduce a very small amount of bleach (a couple of ml's) to pervent further build up whilst I wait for a solution to be delivered. Other option was UV light, but that still something I would need to buy in.
Is there anything that can be done except just striping and cleaning the entire system, replacing the tubing and going with a premix like mayhems?
