Alienware 17 - Dock
18 Oct 2002
ordered this from dell outlet for a decent price, im struggling with docks though. Is there anything I can get that I can slot it into for desktop use coupling it up to a dell 30" dvi-d with mouse and keyboard? I don't seem to see anything
Alienware 17 - R4
16GB (2x8GB) 2667MHz DDR4 Memory Non-ECC
1 TB SATA Hard Drive (7200 RPM)
Power Supply : 330W AC Adapter
512GB PCIe NVMe M.2 Solid State Drive
Primary 6-cell 99W/HR Battery
Processor: Intel® Core™ i7-7820HK (Quad Core, up to 3.90 GHz, 8MB Cache, 45W)
Internal Qwerty Backlit Keyboard
NVIDIA GTX 1080 8GB
17.3inch UHD (3840 x 2160) IPS Anti-Glare 300-nits Display
Can you elaborate? I can't (may just be me) understand what your actually asking here?
Edit : sorry thought you was on about a gpu dock. All I can think of in regards to that is if it has thunderbolt you could get a dongle for that.
For example a TB has the bandwidth to put a mouse keyboard and screen and more over a single cable. So you could leave those parts plugged in and when you get home just plug in the one cable and your away.probably be done a lot cleaner than a "dock" aswell
