Alienware Graphic Card Driver Issue
26 Jan 2013
Hello, I'm new here and I joined mostly to ask a question about my Alienware Area 51 m15x. So the thing is when I switch to external graphic card it seems like drivers are not working, even when I play movie it freezes. Is there anything which can be done or does it need new graphic card ?
A Graphics card is the most essential hardware component of your Alienware Area 51 m15x desktop. You need to keep a check on the updates and the drivers available. Installing the latest drivers and updates is an easy task.
Does it do this with games or is it only with video? If it's only with video, what sort of video? Flash? divx? dvd?
First thing to do is uninstall the GFX drivers, reboot, then run driver-sweeper to clean out all the left over files. Then reboot again and install the GFX driver.
This should hopefully rule out any driver issue.
