hi there, i recently purchased an alienware laptop with the specs:
Components
1 Alienware M17x : Standard Base
1 Processor : 3rd Generation Intel Core i7-3630QM (6MB Cache, up to 3.4GHz w/ Turbo Boost
2.0)
1 Display : 17.3" WideFHD (1920 x 1080) WLED LCD
1 Camera : Integrated Skype HD Certified FullHD Camera with dual digital microphones
1 LCD Back Cover : Soft Touch - Nebula Red
1 Memory : 6144MB (1x2048 + 1x4096) 1600MHz DDR3 Dual Channel
1 Hard Drive : 500GB 7,200 RPM + 32GB mSATA Caching SSD 1 SR
1 Optical Drive : BluRay Combo (Blu-ray read only, DVD, CD read & write)
1 Power Cord : UK 250V
1 Power Supply : Alienware 240W AC Adapter
1 Battery : Primary 9-cell 93W/HR LI-ION
1 Graphics : 2GB GDDR5 AMD Radeon HD 7970M
1 Sound Card : Creative Sound Blaster Recon3Di with THX TruStudio Pro Software
1 Wireless : Intel 2230 Wireless Card + BT
1 Keyboard : Internal UK/Irish Qwerty Keyboard
should be a massive upgrade on the inspiron 17r we have had the past few years, but i had some questions
im not very good with technology etc, but i remember reading that its not that hard to change ram etc on a laptop, but ive had no experience of doing so
does ram for a laptop have to be certain ram? if so what ram would people recommend (its coming with 6gb i think), i think i would like more, how difficult is it to change the ram on these types of laptop (and is there anything special i have to do in the settings etc after to make this register or does it automatically detect it ?)
the other question is regarding a ssd for the laptop, i got a pc recently and im loving the fast boot up times on my crucial m4ssd, again does the drive have to be a certain size to fit , im not really sure what size i want yet, or indeed what make etc
btw i read an article yesterday and in the comments someone was saying that that particular graphics card was full of all sorts of problems with drivers etc and you had to select it rather than the onboard (im assuming on the cpu?) graphics then you had to restart it with the 7970m selected, is this issue likely to be resolved with a fix anytime soon?
thanks all for your help in advanced, im genuinely well excited to get my new toy (always wanted an alienware laptop, i hope i wont be dissapointed)
Components
2.0)
