Alienware M15X GPU?
Permabanned
14 Apr 2012
Hi, I'm going to buy "Alienware M15x Gaming Laptop, Intel i7 840QM 3.2 GHz Turbo CPU, 8GB DDR3 Ram, 500GB SATA HDD, 15.2 inch 1600x900 HD LED Screen"
I was wondering what GPU's I could
put inside of the laptop?
I was hoping for something to play
the latest titles on low at least.
After doing a little bit of research l have found the following cards would be usable.
gtx 460m
gtx 560m
5870m
6970m
6990m
gtx 660m
HD 7970M
The forum.notebookreview.com have a dedicated Alienware M15x Forum, you should be able to find a lot of info there.
Regards
C.
But this is so cheap on the bay, ceuotc which one would you recommend? why can't I use the new GPU's. Do they not fit into these motherboards or is it the motherboard just not being compatible.
You can also upgade to the GTX 680M.
I would either get the GTX 680M or the HD 7970M (may have enduro issue tho as l am not sure the M15x has switchable graphics), to upgrade to these you will need the 240 watt psu.
Google M15x HD 7970 for a upgrade video.
If you are keeping the display at 1600*900 then a GTX 660M will be enough, again Google M15x GTX 660M for more info.
I upgraded the display on my G46VW to 1600*900 as well as adding a i7 3610QM and the GTX 660M has enough grunt to run games at high.
Regards
C.
