Alienware M17 wont hold keyboard light settings
23 Jan 2012
It's the R4...I'm changing them just having a play about (as you do :D), and saving them...or so I think....but when closing and opening from shutdown say....when it's booted up, the keyboard's back to it's default of blue/turquoise....it's not holding the settings. Or is that the way they work
Mine holds the settings so must be an issue, you tried reinstalling the software?
Sam
Never had that problem on any of mine. I think Sam means reinstall alienware command centre thats what controls the lights.
