Alienware Peripherals in stock at OCUK!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
The Alienware TactX range of periperhals are now in stock ready for shipping now at OcUK. These offer great value for money comined with excellent trusted quality.
AlienWare TactX Gaming Headset @ £49.99 inc VAT
The Sound of Victory
The new Alienware TactXTM headset is engineered for high-quality audio performance. Built with a custom-engineered soundscape and optimized to single out key in-game sounds, this headset can definitely give you a clear advantage against your opponents.
Fragging Your Enemies Just Got Easier
Avoid being caught by surprise. The Alienware TactX headset is designed for crisp audio clarity, so you can hear your enemy’s every move.
Retractable microphone
Call for backup with a retractable microphone that stows away when not in use.
Lightweight design
Enjoy endless hours of destruction with a headset designed for extreme comfort and countless hours of extended use. Full-sized ear cushions fit gently around the ears for long-term comfort and background noise reduction.
3-piece construction
Take your game virtually anywhere. Dismantle the headset into 3 separate parts for easy stowing and transport.
Braided audio cord
Sharpen your sense of hearing with impressive sound quality and help prevent degradation of high frequencies with a cord that delivers exceptional sound performance and is designed to withstand the most extreme gaming conditions.
Gold-plated connectors
Enhance signal integrity by optimizing signal transfer and resistance against corrosion and wear.
Headset
• Frequency Response: 16 Hz -28 kHz
• Input Impedance: 40 Ohm
• Sensitivity: SPL @ 1 kHz, 1 Vrms: 110 dB
• Connector: 3.5mm
• Ear Coupling: Circumaural
• Cord Length: ~10 Feet (~3ft cord + ~7ft extension)
Microphone
• Frequency Response: 75 Hz -16 kHzs
• Input Impedance: 2K Ohm
• Sensitivity: -38 dB
• Connector: 3.5mm
• Pick Up Pattern: Unidirectional
System Requirements
• 3.5mm Analog Audio-Out Jacks
• 3.5mm Analog Audio-In Jack (for microphone use)
• No Drivers Required
Only £49.99 inc VAT.
ORDER NOW
Alienware TactX Laser Gaming Mouse @ £44.99 inc VAT
The Alienware TactX mouse delivers pinpoint accuracy and split-second in-game reaction times with an ultra-fast 5000 dpi laser engine. The Alienware TactX mouse features five available user profiles, nine customizable buttons and the exclusive AlienFX lighting system.
- Connectivity Technology : Wired - USB
- Movement Detection Technology : Laser
- Buttons Qty : 9
- Movement Resolution : 5000 dpi
- Features : Scrolling wheel
- Cables Included : 1 x USB cable - integrated - 1.8 m
Only £44.99 inc VAT.
ORDER NOW
Alienware TactX Multi-Colour Backlit Gaming Keyboard @ £69.98 inc VAT
The Alienware TactX Keyboard is designed to enhance your gaming and entertainment experience with a broad array of customization options including dedicated macro keys, support for an unlimited number of user profiles and the exclusive AlienFX lighting system. Enhance your entertainment experience with features like multimedia controls, an anti-ghosting WASD cluster and a gaming mode.
- Colour: Black
- Connectivity Technology: Wired - USB
- Key/Button Function: Multimedia, programmable, macros buttons
- Features: Anti-ghosting
- Connections: 1 x USB - 4 PIN USB Type A
Only £69.98 inc VAT.
ORDER NOW
Correct me if I'm wrong, the headset is a rebranded steelseries 5h? I read that it was somewhere when I was researching headsets.
Also the mouse looks like a logitech g9, does it have the same internals?
Thanks.
