Alienwear m15 Ryzen Edition R5 or legion Pro
3 Nov 2010
I currently have a legion 7 but there is an issue with the display so waiting to see what lenovo will do about it. They have only offered a 5 % discount which is not acceptable.
Noticed that I can get a m15 Ryzen Edition R5 with same rtx 3070 specs as lenovo at £1549 and with current cash back offer on old laptop woukd work out at £1049
The alienwear also has a QHD 240 htz screen
Does the alienwear have a full powered rtx3070
The display on lenovo is lovely but I can't see any reviews on the alienwear screen ie brightness etc
What's the build quality like on the alienwear. Is it up to lenovo standards etc
YouTube reviews support that the Legion 5 Pro has a better cooling solution (better thermals) when compared to the Alienware M15 R5.
The L5P also has a 500 nit QHD+ Display that supports GSync and Freesync.
Finally, the L5P doesn’t have an inverted motherboard, which is pro consumer. (The M15 R5 does which makes repasting the CPU and GPU more of chore).
I have reviewed both (mash IT if you wish to see the reviews) I would get the legion 5 pro every time. The hardest part is actually getting the legion 5 pro though
