Aliexpress filament
  • Thread starter Thread starter JRJ
  • Start date Start date
JRJ
JRJ
21 Oct 2010
I keep getting adverts for eSun/Jayo/Sunlu filaments being sold on AliExpress at considerable reductions to Amazon, any feedback on buying from there? I've always associated AliExpress with copies/lower grade items but the prices seem tempting.
I've found it to be not actually that much cheaper. Most rolls seem to be 0.5kg rather than 1 so it looks really cheap on first sight.
I did notice that, and also lots of bundles of 5 x 250g but there are full 1kg reels and lower prices.
Esun/jayo/sunlu are all good filaments, Jayo is just another brand of one of sunlu and esun but I can't recall which. Whether they are cheaper or not will depend. I usually get any of those on ebay at about £11 a kilo
We got Sunlu stuff for what worked out about £8 a kilo roll, really good stuff so we bought another 15 rolls lol.
  • Haha
Reactions: JRJ
I've had about 15 rolls of Jayo at this point. Last batch was disappointing. PLA Black was snapping while in the PTFE tube and caused the print to stop.
It was good up till then. I'll probably finish this batch before trying another brand.
I'm exclusively using JAYO PLA+ at the moment, works out around £6/kg and prints perfectly for me.
Haven't found it that cheap, which store and quantity are you buying? The last 4-5 rolls I've bought have been Jayo PLA+ but from Amazon at double that price.
A certain Chinese seller mentioned in the thread title, but I believe they come from a UK warehouse.
10x 1.1kg rolls for 59.19 just now. That's for a mix of black and white.
it's really not that much cheaper. if you're going through it in high enough volume then look at gst3d maybe? they do bulk discounts.
You can buy filament from UK for £10-11.
I don't really want to put cheapest stuff into my printer.. Or waste time dealing with failures.
While I can't speak for the quality, AliExpress, is basically a shop front for some Alibaba manufacturers, and is always more expensive. If you want stuff cheaper, but are buying in bulk, use Alibaba, it will be a lot cheaper and will generally be from the same manufacturers on AliExpress.
I've used a few different colours of Sunlu PLA+ and find that I can print using the "Bambu PLA Basic" profile. I've not yet tried Jayo (cheaper brand of Sunlu) yet. Similar with Sunlu dual colour Silk, just worked with Bambu profile.
I can't say the same for the Elegoo PLA and Silk I bought. Needed to use the calibration in Bambu slicer to get the K value right.
