Align particular div
27 Sep 2004
Howdy,
Just a quickie, hopefully. I'm trying to centre align solely the images on my Tumblr blog posts but I can't seem to configure the CSS to allow it. I'm not sure if it's a float issue or whatnot.
Blog here: http://ryanfindlay.tumblr.com/
As you can tell, it's not my theme but I've managed to configure it accordingly so far. The only issue I'm having is finding an appropriate point to insert a centre alignment for the post images.
There's a bit too much CSS to post but if it's easier I can post below.
Thanks in advance!
Centering images can be kind of annoying. Simple ways to do it are...
<center><img></center>
or <p class="align_center"><img></p> and then css .align_center { text-align: center; }
Dunno if those are possible for you.
Can't get either of those suggestions to work, unfortunately. Thanks anyway! The <center> encasing was my first port of call initially.
